Introduction
Change the oil in your '84-'88 Toyota Pickup, with 2.4L I4 engine, to improve engine performance and longevity.
It is typically recommended that you change your vehicle's oil every 3,000 miles for extreme running conditions. However, this number can vary depending on your operating conditions, age of your vehicle, number of miles on your engine and your driving habits. Use of synthetic oils can help reduce engine wear and are advisable for older engines or if your typical driving involves extended periods of stop and go traffic.
Begin by locating the 14 mm hex oil drain plug. The drain plug is on the driver's side of the truck, facing the differential case.
Place the oil drain pan under the oil drain plug.
Once the draining oil has slowed to a drip, clean the area around the drain plug hole with a clean towel or rag and replace the oil drain plug.
Screw in the oil drain plug by hand, turning it clockwise as far as possible. Finish tightening the drain plug by using a 14 mm box end wrench.
Wipe off any oil that may have dripped onto the differential case with a clean rag or towel.
Locate the hood release lever. It is below the driver's console, on the left.
Pull the lever until you hear the hood click.
Go to the front of the truck and locate the hood release latch. It is under the hood and slightly towards the driver's side of the truck.
Lift up on the hood release latch with one hand and lift the hood open with the other.
Place the end of the hood prop rod into the hole on the driver's side of the hood marked by an arrow.
Observe the engine from the passenger side of the engine bay. Look between the pairs of inlet pipes on the side of the engine to find the oil filter.
Use your hand to turn the oil filter counter-clockwise until it comes off the engine's oil filter threads.
Pull the filter out of the engine bay with the threaded open end facing up to reduce the amount of oil spilled. Set the filter aside where it won't fall over.
Locate the oil filler cap. It is on the valve cover, along the cover's center line and towards the front.
Turn the cap counter-clockwise and remove it.
Place a funnel in the oil filler hole.
Locate the oil dipstick. It is a long metal rod with a loop on the end and is just to the right of the oil filler cap.
Pull out the oil dipstick, wipe it off, place it all the way back into its hole and remove it again.
Check the oil level on the end of the dipstick. It should be within the cross-hatched area, or slightly above it.
Add oil if the oil level is below the cross hatched area of the dipstick. Place the oil dipstick all the way back in its hole.
Support the hood with one hand and use your other hand to place the hood prop rod back into its holder.
Gently lower the hood until it clicks into the secondary latch.
Press firmly on the edge of the hood until you hear the primary latch engage.
Start the truck and look for leaks underneath it. If there are leaks, shut the truck off and determine if the drain plug or filter need to be tightened, or if a part has been damaged.
After running the engine for a few minutes, let it cool down for at least an hour and re-check the oil level. If the oil level is more than a 1/2" above the top hole of the dipstick you will need to drain oil. If the oil level is below the bottom hole of the dipstick you will need to add oil.
Place the old oil filter in the oil drain pan with its open end facing down and allow 12-24 hours for all the oil to drain out of your old oil filter.
Take your old oil and filter to a recycling facility. Most auto parts stores and repair shops accept these at no charge. In addition, some cities and/or counties have a service where they will collect used oil and filters from your home. For more information, see the American Petroleum Institute's web page on used motor oil collection and recycling.
9 other people completed this guide.
One Comment
I have 88 Corolla …..Efi 16 valve engine…what will be it's engine oil capacity
