Introduction
私のスバルのキーレスエントリーボタンがうまく機能しなくなったので、その中のバッテリーを交換することにしました。 この手順は比較的簡単で、他のほとんどのメーカーのキー・フォブにも基本的に同じ方法を適用できます。
#1のプラスドライバを使用して、キー・フォブの背面にあるプラスネジを一つ外します。
二つの黒いプラスチックケースを分離すると、コントロールモジュールが見えます。コントロールモジュールをキーの残りの部分から持ち上げます。
デバイスを組みなおすには、以下の手順を逆の順序で実行してください。
24 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
19 Comments
All fine and good, except the identical looking key fob from my 2010 Outback uses a CR1620 battery. So much for the CR2025s I bought!
Nice, clear description of the process (which is very simple). My 2010 Outback also uses the CR1620 battery, not the CR2025 the instructions say. I would recommend disassembling your key fob and taking the old battery to the store to compare. You can still drive with the disassembled key fob; you just have to lock/unlock the door manually.
Great instructions! However, just like Mark and Janet, my 2010 Legacy keys had a CR1620 battery. Also, there were 4 plastic clips on step 2. Thanks for the guide!
Apparently the instructions have been updated since the above comments, because they now call for the CR1620, which is what I bought, and they work perfectly!
The instructions and photos are very clear, easy to follow, and accurate. I was very pleased to find this site and realize that for about 15 bucks total I could replace the batteries in both our 2010 Outback keys - I had imagined we'd have to get new keys or at the least take them to the dealer for a highly pricey replacement. Thanks, ifixit!!
Question, I replaced mine but it still doesn't work. do I need to reset the system?
