Introduction
去年的Galaxy Note7
煽动了我们对于智能手机不满情绪的火焰。 也真的燃起了火焰。 现在火焰回来了,转世为"盖乐世 Fan Edition"让我们把它拆解开吧!希望这次不要再有火焰了。 有关更详细的分析请参阅我们下面的链接Note Fan Edition blog post.
时刻关注我们最新的维修新闻:关注我们的推特,脸书和Instagram。
Video Overview
请阻止我们,如果您先前听到过这些数据
曲面5.7" Super AMOLED 显示屏 分辨率为2560×1440(518 ppi) 以及 大猩猩5代玻璃。
Exynos 8890 Octa Core处理器,具有4 GB RAM + Mali-T880 MP12 GPU
1200万像素,ƒ/ 1.7的后置摄像头,具有OIS,双像素自动对焦,4K视频; 500万像素/ 1080p自拍前置相机
64 GB内部存储,另外可通过MicroSD扩展最大到256 GB
虹膜识别,指纹识别
S Pen,USB-C 和耳机插孔
IP68防护等级
手机有了全新的电池。 这一块6月20日生产,所以是真的新款手机。
12.32Wh与上一代13.48Wh相比,电池容量的确小了些
但这块电池容量还是比iPhone 7 Plus Teardown (11.1Wh)要大,缩减9%的容量来使得Note 更加安全。
有一些传言说,这个翻新的手机将配备一个较新的骁龙 821处理器来替换Note7中的三星Exynos Octa 核心。 所以我们卸下了CPU上的保护壳,仔细看看:
三星K3RG2G20CM-CGCJ 4GB LPDDR4 RAM分层在Exynos 8890 Octa Core CPU
Samsung KLUCG4J1CB-B0B1 64GB UFS 2.0
- 许多组件是模块化的,可以独立更换。
- 改进的走线意味着充电端口可以在不拆下显示屏的情况下移除。
- 电池可以在不用拆卸主板的情况下移除,但是粘合剂将其牢牢粘住,使得更换变得困难。
- 前后玻璃面板增加了两倍的裂痕,后玻璃面板的强力的粘合剂使得很难进入设备。
- 由于曲面屏,移除玻璃屏幕而做到不伤害显示屏几乎是不可能的。
Final Thoughts
Repairability Score
(10 is easiest to repair)
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
23 Comments
Everyone keeps calling it the 'fan' edition, but I can't see a fan anywhere. You'd think there would be space next to the smaller battery, and the fan could also help stop it exploding.
- Bob from Hartlepool.
Doubt it'd be worth the effort, since the OG Note 7 they showed was a VZW model, which got software updates to disable charging, along with most of the other Note 7's out there.
JJ Davis -
JJ Davis Reply is totally lame. It wasn’t hard to dodge the Poison Pill Update that prevented the Note 7 from charging. I did. And my N7 is still my daily driver in Dec 2019 … however, it is time for a new battery … and my hope is the Note FE battery is the replacement … which I am trying to discover.
Preston -
On my of note 7 now which is supposedly imei blocked in Australia but my stock note 7 is magic & gets cellular data again after being wifi only for a while there. Still 100% charge & blocked all updates. Never a sign of heating. I think the early ones from 1st recall of exynos versions were safe b4 the got flooded trying to replace all the usa 820 versions too. Mine has never been over 38degrees when my note5 died from overheating. I use fast wireless&wired & never an issue with heat. I even slept on it once so no sharp welding bits in my battery. I get led covers too. I wanna find a cheap s view cover. I've got a spare black one too i may root as i got an s7e for its imei.that 1 is blocked. Hopefully I can clone this 1 over with all its app data to keep the disabler apps working but i can root or keep for spares.might order a new back glass just in case. Note7 is still the greatest. Last sammy with real buttons.
