Sony Handycam HDR­-CX220 Display Screen Replacement
  1. Sony Handycam HDR­-CX220 Display Screen Replacement, Battery: step 1, image 1 of 1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Display Screen Replacement: step 2, image 1 of 1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: step 3, image 1 of 3 Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: step 3, image 2 of 3 Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: step 3, image 3 of 3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Display Screen Replacement: step 4, image 1 of 3 Sony Handycam HDR­-CX220 Display Screen Replacement: step 4, image 2 of 3 Sony Handycam HDR­-CX220 Display Screen Replacement: step 4, image 3 of 3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Display Screen Replacement: step 5, image 1 of 1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: step 6, image 1 of 2 Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: step 6, image 2 of 2
    • Use the Phillips #0 screwdriver to remover the two (5mm) screws on the outer part and one (3mm) in the middle.
    • In the second image, there is a second screw on the opposite side of the screen hinge. This screw is not shown, but must also be removed.
  7. Sony Handycam HDR­-CX220 Display Screen Replacement: step 7, image 1 of 1
    • Use the plastic opening tool to remove the plastic case protecting the screen
    • Pull it gently not to damage anything under the case
  8. Sony Handycam HDR­-CX220 Display Screen Replacement: step 8, image 1 of 2 Sony Handycam HDR­-CX220 Display Screen Replacement: step 8, image 2 of 2
    • Use the Phillips #0 screwdriver to remove the 2 screws shown
    • Use your hands to carefully unhook the screen from the highlighted hook
    Display Patti kaha milega
    Ayush Raj SK - Reply
  9. Sony Handycam HDR­-CX220 Display Screen Replacement: step 9, image 1 of 3 Sony Handycam HDR­-CX220 Display Screen Replacement: step 9, image 2 of 3 Sony Handycam HDR­-CX220 Display Screen Replacement: step 9, image 3 of 3
    • Use your hands to carefully remove the tape
    • After removing the tape, pull on the wire disconnecting it from the screen.
4 other people completed this guide.
Keven
811 Reputation
6 Guides authored
3 Comments
How do you mount hdr cx220 lcd cable flat? can you help me?
Rafael Oliveira - Reply
gjhgvnvyh n hygfv
ANM WORLD - Reply
We have a camera 220. Whose dipstick display strip has deteriorated again. Where can I find this strip? Video is good information so that's why
ANM WORLD - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 2,474
