Introduction
The replacement of the buttons are necessary if you are struggling to manage through your menus, or having trouble pressing the buttons in general.
  1. Push in the battery indicator.
    • Push in the battery indicator.
  2. Slide the battery out of the slot.
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Use the Phillips #0 screwdriver to remove the two 5mm screws. Use the Phillips #0 screwdriver to remove the two 5mm screws. Use the Phillips #0 screwdriver to remove the three 5mm screws.
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  5. Use the plastic opening tool to loosen the plastic case of the camcorder. Use the plastic opening tool to loosen the plastic case of the camcorder. Use the plastic opening tool to loosen the plastic case of the camcorder.
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  6. Use your hands to remove the plastic case.
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  7. Use the Philips #0 screwdriver to unscrew the two 5mm screws shown on top of the camera. Remove the one side 5mm screw using a Philips #0 Screwdriver. Remove the top buttons from the hook.
    • Use the Philips #0 screwdriver to unscrew the two 5mm screws shown on top of the camera.
    • Remove the one side 5mm screw using a Philips #0 Screwdriver.
    • Remove the top buttons from the hook.
  8. Unplug the connected wire shown. Pull gently not to cause any damage.
    • Unplug the connected wire shown.
    • Pull gently not to cause any damage.
Keven
691 Reputation
6 Guides authored
One Comment
hi, can you please tell me where can I buyStep 6 Buttons?
thanks
jesus - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 299
