This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
К счастью, замена аккумулятора на iPhone 4 требует минимальной разборки.
Video Overview
Задняя панель вашего iPhone может быть прикручена #000 Phillips(крестовыми) винтами или Apple 5-ти конечными "Pentalob" винтами(второе изображение). Проверьте какие винты использованы у вас и убедитесь что у вас есть необходимая отвёртка для их удаления.
Удалите два 3.6 мм Pentalob или Phillips #000 винты около разъёма.
5-ти конечная отвёртка используется только один раз.
Удалите 2.5 мм винти Phillips(крестовой), крепящий разъём аккумулятора к материнской плате.
Следуйте этим инструкциям в обратном порядке, чтобы собрать устройство.
2245 other people completed this guide.
Special thanks to these translators:
57%
Jasper Fleischhauer is helping us fix the world! Want to contribute?
Start translating ›
Attached Documents
131 Comments
When I put the battery in, the lead going from the battery to the plug was fully extended. You need to fold it back on itself - look at the shape of the battery you just removed.
Unfortunately, I didn't realize this until AFTER I clipped the new battery in. I tried to align the battery to where it should go while it was still connected, in the process I broke one of the soldered connections on the battery connector. Wouldn't boot up and did the continuous battery recycling.
Luckily, I was able to put the old battery back in and all was working again. I don't think I'll attempt a new battery at this point...
yes they need to add that
Tim -
Now that I put my old battery back in, my phone turns on but won't charge. Great. I have 68% until I have a dead phone, no battery. The battery I got from ifixit was a dud. This is a complex process--I've changed out displays on a laptop, hard drives, cpus. This is NOT a "moderate" job and needs major rework on their tips.
