ネジ穴の潰れたカウンターサンク六角ボルトを取る
  1. ネジ穴の潰れたカウンターサンク六角ボルトを取る, ネジ穴の潰れたカウンターサンク六角ボルトを取る: step 1, image 1 of 1
    • ネジ頭をスロット状に切ります。
    • マイナスドライバーをスロットに入れ、反時計回りにハンマーで軽く叩きボルトを緩めます。
    • ドライバーでボルトを外します。
Finish Line
44 other people completed this guide.
Special thanks to these translators:
en jp
100%
uozumi is helping us fix the world! Want to contribute?
Start translating ›
Wolfgang
597 Reputation
2 Guides authored
6 Comments
Use the same technique for Philips or crosshead screws.
Use a grinding / cutting disk, not a saw blade. Apply the rotating cutting disk gently, do not force or it will break.
If this is a toughened steel or stainless steel bolt (much tougher), it will be best to use a reinforced cutting disk.
Use a dusk mask to avoid breathing the dusk from the disk !
(No, I don't usually, but I should !)
Frank B - Reply
While this works it is very difficult to not ruin the material around the bolt.
What I do is use a torx bit. size one up that is slightly larger then the hole and then firmly tap it in. atttach your drive handle a turn slowly while pushing down. this will normally break it free.
Also before your get to this point try putting your allen key in the hole and smack it with a hammer. sometimes the force of the hit will cause the metal to "break" enough that the allen screw wont strip.
Jamie Mcguire -
There are also specifically designed screw extractors made for this. These tools are generally two-sided: one side is used to drill the hole, while the other is inserted to extract. If the process works, the surrounding area is undamaged.
Karl Kaufmann - Reply
Use another Allen bolt to weld over it and then you can easily remove the Allen bolt with the help of Allen key
Tushar Pednekar - Reply
And if for any reason if you can't weld then just drill the head of the Allen bolt so it's shears off. And then u can easily remove the rest
Past 24 Hours: 11
Past 7 Days: 96
Past 30 Days: 461
All Time: 258,350
