Samsung Galaxy S5 Motherboard Replacement
  1. Samsung Galaxy S5 Motherboard Replacement, Rear Case: step 1, image 1 of 3 Samsung Galaxy S5 Motherboard Replacement, Rear Case: step 1, image 2 of 3 Samsung Galaxy S5 Motherboard Replacement, Rear Case: step 1, image 3 of 3
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy S5 Motherboard Replacement, Battery: step 2, image 1 of 3 Samsung Galaxy S5 Motherboard Replacement, Battery: step 2, image 2 of 3 Samsung Galaxy S5 Motherboard Replacement, Battery: step 2, image 3 of 3
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
  3. Samsung Galaxy S5 Motherboard Replacement, microSD Card: step 3, image 1 of 2 Samsung Galaxy S5 Motherboard Replacement, microSD Card: step 3, image 2 of 2
    • Using a fingertip, pull the microSD card straight down out of its slot.
    • Remove the microSD card from the phone.
  4. Samsung Galaxy S5 Motherboard Replacement, SIM Card: step 4, image 1 of 1
    • Repeat the above procedure to remove the SIM card.
  5. Samsung Galaxy S5 Motherboard Replacement, Display Assembly: step 5, image 1 of 3 Samsung Galaxy S5 Motherboard Replacement, Display Assembly: step 5, image 2 of 3 Samsung Galaxy S5 Motherboard Replacement, Display Assembly: step 5, image 3 of 3
    • Use a plastic opening tool to pry up the plastic midframe connector panel.
    • Remove the connector panel with a pair of tweezers.
    • There should be enough adhesive to readhere the panel upon reassembly, otherwise use a small amount of double-stick tape.
  6. Samsung Galaxy S5 Motherboard Replacement: step 6, image 1 of 2 Samsung Galaxy S5 Motherboard Replacement: step 6, image 2 of 2
    • Use the sharp tip of a spudger to pry the home button cable connector straight up off its socket.
  7. Samsung Galaxy S5 Motherboard Replacement: step 7, image 1 of 2 Samsung Galaxy S5 Motherboard Replacement: step 7, image 2 of 2
    • In the following steps you will be using an iOpener to warm the adhesive affixing the display assembly to the rest of the phone. This will allow for a safer, easier screen removal. For proper iOpener use, follow our iOpener heating guide, make sure to pay attention to all warnings.
    • Place a heated iOpener on the left side of the phone for at least 90 seconds.
    • Reheat the iOpener and place it on the right half of the phone.
  8. Samsung Galaxy S5 Motherboard Replacement: step 8, image 1 of 2 Samsung Galaxy S5 Motherboard Replacement: step 8, image 2 of 2
    • In the following steps you will be using an opening pick to separate the adhesive securing the front panel glass. Only pry where directed. If you experience resistance, stop sliding the opening pick and reapply heat.
    • Insert the edge of an opening pick underneath the bottom right side of the front glass.
  9. Samsung Galaxy S5 Motherboard Replacement: step 9, image 1 of 3 Samsung Galaxy S5 Motherboard Replacement: step 9, image 2 of 3 Samsung Galaxy S5 Motherboard Replacement: step 9, image 3 of 3
    • Slide the opening pick up along the right side of the display.
  10. Samsung Galaxy S5 Motherboard Replacement: step 10, image 1 of 3 Samsung Galaxy S5 Motherboard Replacement: step 10, image 2 of 3 Samsung Galaxy S5 Motherboard Replacement: step 10, image 3 of 3
    • Carefully slide the pick around the corner, stopping before the speaker grille at the top of the phone.
  11. Samsung Galaxy S5 Motherboard Replacement: step 11, image 1 of 3 Samsung Galaxy S5 Motherboard Replacement: step 11, image 2 of 3 Samsung Galaxy S5 Motherboard Replacement: step 11, image 3 of 3
    • The adhesive securing the top of the phone is only a narrow strip above the earpiece speaker. Slide the pick along the top of the speaker to avoid damaging internal components.
    • Slide the opening pick across the top of the phone, being very careful not to insert the pick too deeply.
  12. Samsung Galaxy S5 Motherboard Replacement: step 12, image 1 of 3 Samsung Galaxy S5 Motherboard Replacement: step 12, image 2 of 3 Samsung Galaxy S5 Motherboard Replacement: step 12, image 3 of 3
    • Carefully slide the pick around the upper left corner.
    • If you encounter any resistance from cooling adhesive, reapply a heated iOpener to the left side of the phone.
  13. Samsung Galaxy S5 Motherboard Replacement: step 13, image 1 of 3 Samsung Galaxy S5 Motherboard Replacement: step 13, image 2 of 3 Samsung Galaxy S5 Motherboard Replacement: step 13, image 3 of 3
    • Slide the opening pick down along the left half of the phone stopping at the lower left corner.
  14. Samsung Galaxy S5 Motherboard Replacement: step 14, image 1 of 2 Samsung Galaxy S5 Motherboard Replacement: step 14, image 2 of 2
    • Slide the opening pick all the way to the bottom left corner of the phone, making sure it is securely placed.
    • In the following step you will be placing an iOpener over the home button end of the phone, you won't want your opening pick to slip out.
  15. Samsung Galaxy S5 Motherboard Replacement: step 15, image 1 of 1
    • Place a reheated iOpener over the bottom portion of the display assembly.
    • There are delicate components in this portion of the phone, you want to ensure the adhesive is warm and easy to loosen to protect the phone.
  16. Samsung Galaxy S5 Motherboard Replacement: step 16, image 1 of 3 Samsung Galaxy S5 Motherboard Replacement: step 16, image 2 of 3 Samsung Galaxy S5 Motherboard Replacement: step 16, image 3 of 3
    • The bottom end of the phone contains the soft button and home button ribbon cables. If you insert the opening pick too far into the phone you risk cutting these cables.
    • Slide the very end of the opening pick across the bottom edge of the display to separate the last of the remaining adhesive.
  17. Samsung Galaxy S5 Motherboard Replacement: step 17, image 1 of 2 Samsung Galaxy S5 Motherboard Replacement: step 17, image 2 of 2
    • Twist the opening pick to detach the glass from the phone.
    • If the front panel does not detach easily, it may require additional adhesive cutting.
  18. Samsung Galaxy S5 Motherboard Replacement: step 18, image 1 of 2 Samsung Galaxy S5 Motherboard Replacement: step 18, image 2 of 2
    • If the front panel is not easily freed, the adhesive on the soft button cable may need to be separated.
    • These cables are thin and easily damaged, therefore be certain you are only peeling them off the display assembly and not lacerating them.
    • Insert an opening pick under the soft button icons on the display and pry the button cables down off the inside of the front panel.
  19. Samsung Galaxy S5 Motherboard Replacement: step 19, image 1 of 2 Samsung Galaxy S5 Motherboard Replacement: step 19, image 2 of 2
    • Slightly lift, but do not remove, the home button end of display assembly.
    • Do not remove the front panel entirely. It is still attached by a connector.
    • If you are reusing the home button flex cable, be careful not to sever the cable from the home button. Adhesive can cause the cable to rip apart from the home button. While the home button will still work, the fingerprint scanner will not.
  20. Samsung Galaxy S5 Motherboard Replacement: step 20, image 1 of 3 Samsung Galaxy S5 Motherboard Replacement: step 20, image 2 of 3 Samsung Galaxy S5 Motherboard Replacement: step 20, image 3 of 3
    • Use the sharp tip of a spudger to lift the front panel assembly cable connector straight up off its socket on the motherboard.
    • Safely remove the front panel assembly from phone.
    • If your replacement display did not come with a home button, follow our Home Button Assembly guide to transfer your old button over to the new display, or install a new button.
  21. Samsung Galaxy S5 Motherboard Replacement, Interior Midframe Assembly: step 21, image 1 of 1
    • Remove the ten 3.4 mm Phillips #000 screws from the display side of the midframe.
  22. Samsung Galaxy S5 Motherboard Replacement: step 22, image 1 of 1
    • Flip the phone over and remove the following screws from the battery side of the midframe:
    • Two 4.4 mm Phillips #000 screws near the USB port on the battery side of the phone
    • One 4.4 mm Phillips #000 screw
  23. Samsung Galaxy S5 Motherboard Replacement: step 23, image 1 of 3 Samsung Galaxy S5 Motherboard Replacement: step 23, image 2 of 3 Samsung Galaxy S5 Motherboard Replacement: step 23, image 3 of 3
    • Gently run a plastic opening tool down along the left inner side of the interior frame to separate the three white plastic clips.
  24. Samsung Galaxy S5 Motherboard Replacement: step 24, image 1 of 2 Samsung Galaxy S5 Motherboard Replacement: step 24, image 2 of 2
    • The midframe is composed of two halves that encase the motherboard.
    • Gently pull the long sides of the silver bezel out away from the phone to separate the two halves of the midframe.
    • It may be helpful to gently push in from the inside of the battery compartment, but be careful not to flex the interior half of the midframe, as the motherboard is mounted to it.
  25. Samsung Galaxy S5 Motherboard Replacement: step 25, image 1 of 2 Samsung Galaxy S5 Motherboard Replacement: step 25, image 2 of 2
    • Continue on to the right side of the silver bezel, pulling away from the interior section of the midframe to separate the two halves.
  26. Samsung Galaxy S5 Motherboard Replacement: step 26, image 1 of 2 Samsung Galaxy S5 Motherboard Replacement: step 26, image 2 of 2
    • Use a plastic opening tool to pry any remaining corners out of the silver bezel.
  27. Samsung Galaxy S5 Motherboard Replacement: step 27, image 1 of 2 Samsung Galaxy S5 Motherboard Replacement: step 27, image 2 of 2
    • Carefully remove the interior midframe/motherboard assembly from the white inner midframe.
  28. Samsung Galaxy S5 Motherboard Replacement, Motherboard Assembly: step 28, image 1 of 2 Samsung Galaxy S5 Motherboard Replacement, Motherboard Assembly: step 28, image 2 of 2
    • Carefully wedge the tip of a spudger underneath the antenna cable connector.
    • Delicately lift the spudger directly upwards to disconnect the antenna connector off its socket on the motherboard.
    • Some models have two antenna cables (blue and grey/white). Remove both of the cables.
  29. Samsung Galaxy S5 Motherboard Replacement: step 29, image 1 of 1
    • Remove the single 3.0 mm Phillips #000 screw securing the motherboard to the midframe.
  30. Samsung Galaxy S5 Motherboard Replacement: step 30, image 1 of 2 Samsung Galaxy S5 Motherboard Replacement: step 30, image 2 of 2
    • Pull, but do not remove, the camera end of the motherboard up from the midframe to allow access to the connectors on the rear.
    • Do not attempt to fully remove the motherboard as it is still attached to the interior midframe by the Micro-USB port daughterboard connector.
  31. Samsung Galaxy S5 Motherboard Replacement: step 31, image 1 of 2 Samsung Galaxy S5 Motherboard Replacement: step 31, image 2 of 2
    • Use the flat end of a spudger to pry the daughterboard connector straight up off its socket on the motherboard.
  32. Samsung Galaxy S5 Motherboard Replacement, Motherboard: step 32, image 1 of 3 Samsung Galaxy S5 Motherboard Replacement, Motherboard: step 32, image 2 of 3 Samsung Galaxy S5 Motherboard Replacement, Motherboard: step 32, image 3 of 3
    • Use the flat end of a spudger to disconnect the front-facing camera connector off its socket on the motherboard.
    • Remove the front-facing camera from the motherboard.
  33. Samsung Galaxy S5 Motherboard Replacement: step 33, image 1 of 3 Samsung Galaxy S5 Motherboard Replacement: step 33, image 2 of 3 Samsung Galaxy S5 Motherboard Replacement: step 33, image 3 of 3
    • Use the flat end of a spudger to disengage the rear-facing camera connector straight up off its socket on the motherboard.
    • Remove the rear-facing camera from the motherboard.
87 other people completed this guide.
Sam Goldheart
465,744 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,816 Guides authored
25 Comments
Do you know if I can put a g900p motherboard in the G900I in order to get FM radio. Cheers.
James Dean - Reply
In Step 28 you will figure out that there is a second antenna cable that is brown and needs to be detached as well. It is alligned in one row with the blue antenna cable.
Manuel Moebius - Reply
I want to use the motherboard from a T-Mobile galaxy s5 on an AT&T galaxy s5 I just wanted to know if it fits inside the att version because my SIM card reader is broken so I wanted to know if I could use one from T-Mobile and that it would fix and work
Ernesto Rosales -
It would fit and work
Ernesto Rosales - Reply
I dropped my Galaxy S5, gps for maps, compass etc... works fine, but for Endomondo and Strava that requires a location is not working, before the problem it showed GPS signal Ready, Now it just keeps ideling looking for location (GPS), dissasemble to check for any loose connector or loose screw and found nothing, What can be wrong and how to fix it?
Regards
Ralph Wall - Reply
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 75
All Time: 126,535
