2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
F2S26VWDVP1
Background
The Husky Air Compressor F2S26VWDVP1 is a portable air compressor. It includes a 26-gallon vertical air tank and a 2 HP pump that is lubricated with oil. This pump has the capacity to deliver an airflow of 5.7 cubic feet per minute (CFM) at a pressure of 90 pounds per square inch (PSI).
The Husky F2S26VWDVP1 is typically utilized in home workshops, automotive service, and small construction jobs. The pump, lubricated with oil, offers cooler operating temperatures and less wear and tear. The 26-gallon tank leads to longer periods between start-up cycles. The compressor has two universal quick connect outlets, which allow for the attachment of air tools and accessories, and it can operate multiple tools simultaneously. The power cord, measuring six feet, provides some flexibility in where the compressor can be placed.
Technical Specifications
- Model Number: F2S26VWDVP1
- Product Type: Air Compressor
- Tank size: 26 gallons
- Pump type: Oil-lubricated
- Horsepower: 2 HP
- Voltage: 120V
- Amperage: 15 Amps
- Max pressure: 135 PSI
- Air delivery: 5.7 CFM at 90 PSI
- Pump RPM: 1725
- Outlets: (2) universal quick connect outlets
- Power cord length: 6 ft
- Dimensions: 24 x 24 x 50 in
- Weight: 103 lbs
Warranty
The Husky Air Compressor F2S26VWDVP1 comes with a limited warranty of 2 years. This warranty covers any defects in materials and workmanship that might occur during this period. It is important to keep in mind that the warranty is valid only with proof of purchase and the assurance of proper maintenance. In order to claim the warranty, one will need to provide the required proof of purchase and demonstrate that the product has been maintained correctly.
Husky 20/26-Gallon Portable Air Compressor Use and Care Guide
