No Image
This wiki is missing a device image. Help improve this page by uploading one!
Page Stub
This wiki page is a stub. Help us improve this page by adding information to it!
Ask a Question
There are no questions. Be the first to ask a question!
Models
C302H
Background
The Husky Air Compressor C302H is a device that converts power into potential energy stored in pressurized air, also known as compressed air. The compressor is designed for various applications including home do-it-yourself projects, automotive services, and light industrial tasks.
The Husky C302H is equipped with a 2 horsepower, oil-lubricated pump and a 6-gallon tank. It runs on 120V household current and can reach a maximum pressure of 135 PSI. The device is designed with a cast-iron cylinder and valve plates, an overload guard to prevent overheating, a steel tank coated with powder for corrosion resistance, a pressure gauge, a safety valve, and two universal connectors for attaching air tools or inflator nozzles. It is portable, weighing 54 pounds with a metal handle on top, and it stands on rubber feet. The overall dimensions of the unit are approximately 20 x 18 x 40 inches.
Technical Specifications
  • Model Number: C302H
  • Product Type: Air Compressor
  • Horsepower: 2 HP
  • Tank Capacity: 6 gallons
  • Maximum Pressure: 135 PSI
  • Power Supply: 120V household current
  • Pump Type: Oil-lubricated
  • Cylinder Material: Cast iron
  • Motor Protection: Overload guard
  • Tank Material: Powder coated hot-rolled steel
  • Additional Features: Pressure gauge, safety valve, two universal quick connectors
  • Stability: Rubber feet
  • Portability: Metal carry handle
  • Weight: 54 pounds
  • Dimensions: 20 x 18 x 40 inches (LxWxH)
Warranty
The Husky Air Compressor C302H comes with a 2-year limited warranty. This warranty covers defects in materials and workmanship, thus providing assurance against any manufacturing flaws that may arise. However, it's important to note that this warranty is only valid for the original owner and requires proof of purchase to be claimed. Any damage resulting from misuse or accidents is not covered by this warranty. Therefore, care should be taken to use the product as intended and keep it safe from potential mishaps. To claim the warranty, you will need to present your proof of purchase, so it's advisable to keep all relevant documents in a safe and accessible place.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 342
