Model number NV370. Stands 27 inches tall and features Shark’s never loses suction technology and swivel steering.
27 Questions View all
If the vacuum is not turning on, what should I do?
I turned on the power button but the vacuum is still not starting.
Score 8
Add a comment
Most Helpful Answer
If your Shark Navigator Lift-Away Pro refuses to turn on, use this Shark Navigator Lift-Away Pro Won’t Turn On problem page for possible causes and solutions.
First, make sure your vacuum is plugged in. If it is plugged in and the power button is on, you may need to reset your circuit breaker. If that option doesn't work, try resetting the motor thermostat. The steps to reset the motor thermostat can be found on the troubleshooting page.
If none of the above work, your cord may be broken.
Score 2
Add a comment
My shark model # AH452 31 won't turn on.
Score 1
Add a comment
The lights come on but the vacuum doesn’t work
Score 1
Add a comment
Plugged in good circuit and plug no power still
Add a comment
Add your answer
Molina Oung will be eternally grateful.
Past 24 Hours: 37
Past 7 Days: 237
Past 30 Days: 1,513
All Time: 58,824
