PowerBook G4 Aluminum laptops with 17" displays. Released by Apple in 2003.
171 Questions View all
My memory slot is not working how can I fix it?
Am using Poerbook G4 17", when I put it on it beebs twice then the power light will flash twice and stay on but there will be no display, when I change the memory at times it works and sometimes it doesn't, what is causing the problem, because I've fix in new memory and still it doesn't work?
Score -1
Add a comment
Chosen Solution
The PB alus were notorious for having problem with the lower ram slot. On a faulty unit the ram stick installed in the lower slot is not seen by the computer. It's a harware issue and the only way to repair is a logic board replacement.
In you case the two beeps means that you try to use EDO memory. Are you sure that you have compatible memory for you PB ?
Computer beeps twice at startup
1. Two beeps means that EDO memory is installed in the RAM expansion slot. The
PowerBook does not accept EDO memory.
2. Replace RAM card(s) with known-good and compatible RAM and restart.
• If symptom repeats, replace logic board.
Score 2
1 Comment:
professional answer +
by
Add a comment
Hmm, I seem to remember something about the the PowerBooks having motherboard issues with memory. I think that Apple later said it was a defect. Have you taken it to an Apple store? They may be able to fix your problem. If not, come back here.
Add a comment
Add your answer
Johnson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,670
