Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3236 Questions View all
water damaged iPhone 4, replaced dock and battery, won't turn on?
A few weeks ago my iPhone 4 fell into a water basin at the top of a mountain. I replaced the dock connector and battery along with cleaning off the circuitry with iso 99.9%. After putting it all back together, still nothing. I get a blank screen and no recognition from my macbook. What more can i do to fix this problem? i ordered a replacement screen but i don't know if that will do anything since it won't charge and will certainly not turn on.
Add a comment
1 Answer
Chosen Solution
Hey Alex,
It sounds like you have tried all of the main fixes for water damage. Unfortunately, since the dock connector and battery replacement did not fix your problem, it is highly likely that the water caused a short on the logic board, effectively frying it. Did you happen to notice any burn marks on the logic board while you were inside it? You can open the device back up and check to make sure that you reattached all of the connectors correctly, but in the end it sounds like you will have to replace the logic board.
Before doing so, you might as well take it into an Apple Store and seeing if they will replace it for free. It is a long shot, but I have had some luck on them replacing a water-damaged device before.
Hope this helps. Good luck!
Score 1
Add a comment
Add your answer
alex will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,919
