Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
779 Questions View all
Liquid spill, no chime, no display :(
I am working on a 2011 macbook pro 13 i5. It had a liquid spill in the are of the lcd data cable.
No chime. No display.
I removed the logic board and cleaned the are twice with alcohol then dried with compressed air.
When I plug in the ac adapter the hard drive will spin. No chime , no display. no lights.
If I do a shift control option power button, then press the power button to start I get nothing. If I wait 15 seconds after the above reset to hit the power button to start I get a high speed fan.
If I hold the power button in while the fan is running then let go the fan will spin down like to shut off but instead of shutting off will go back to high speed after stopping.
The ac adapter end is bright green and will charge the battery turning orange.
It acts the same on AC or battery power.
I have removed dvd and other cable with no affect.
I would like to try and start it without the keyboard but am not sure of the jumpstart pad connection.
Also on this model it looks like they are feeding the inverter thru the data cable. Is that correct?
Well thanks for listening and any ideas would be appreciated.
Score -1
Add a comment
1 Answer
Chosen Solution
Sounds like a blown logic board. The alcohol should be 98% lower percentages still have too much water. FWIW "drying" with air is never a good idea... it can blow moisture into places that weren't wet, and leave moisture in tight places. Packing in a descant for 72 hrs is a much better drying procedure.
See this Answer under ABCellars's comment for location of jumpers.
If this answer was helpful please remember to return an mark it Accepted.
Score 1
1 Comment:
Ok thanks for your reply.
It would seem reasonable to think that blowing the logic board off with compressed air after being immersed in alcohol would be an excellent way to remove the alcohol and also get under and around the chip pins.
Possibly followed by the 72 hr drying method.
The link on the jumper positions would have been more helpful if they had followed up with a picture.
In my original post I mentioned the "inverter" but meant the led backlight power source as far as cabling from the logic board.
Ill keep working on this for a while.
Any further ideas would be appreciated.
by
Add a comment
Add your answer
Michael will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,543
