DOA, missing ram, blinking power light, black screen, what to do next?
I just got a second hand MacBook Pro model A1212. When I turn on the computer the power light keeps blinking, the screen is black. I tried opening up the computer and discover that the RAM is missing. I would like to get the computer to a working condition so I am just curious is there any way I can test the computer to see if I should replace the missing RAM? Or is that a common symptom (ie black screen) when the RAM is missing?
Thanks,
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
You've got to have RAM for that machine to work. And with some models no Chime. flashing light means I can't boot without RAM. So to further conduct diagnosis you must have at least 2 GB installed as two modules, no slots free.
*Apple officially supports a maximum of 3 GB of RAM but third-parties have been able to upgrade the system to 4 GB of RAM using two 2 GB memory modules with some limitations..
VRAM is on the VGC(VPU) so that's no contributing reason for the black screen. - But NO RAM, POST failure is - Look at the logic board for liquid residue or corrosion ( a likely reason for pulling the RAM).
If this answer was helpful please remember to return an mark it Accepted.
Score 1
Comments:
Thank you so much for the advice. I plug in 1GB of RAM and sure enough it powered up and everything seems fine.
by
Add a comment
Add your answer
Paul will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 673
