Why my MacBook can't power up?
Today I followed the step to remove the logic board and the fan, and then I cleaned the dust, assembled again.
But.....no light on MagSafe, and when pressing the power button, there was no life sign....
I'd tried SMC, but no life sign neither.
I wonder what the problem might be?
Thank you.
Comments:
Why did you remove the logic board? Was it not starting before reassembly?
by
I wanted to clean up the CPU side on the Logic Board and touch pad, they were covered with dust. But....you know the rest. Thank you fellows, I will try you suggested. English is not my primary language, so there might be mistakes in grammar.
by
It worked fine before reassembly, an insect crawled into the computer and I found its dead body.
by
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
If you removed the heat sink you must reapply a thin coat of thermal paste. (This would not cause a power on failure, but you don't mention reapplying thermal paste - it is an essential step to stop overheating)
Double check the reassembly of all the connectors, especially those to the internal mag-safe, keyboard and the HD. They are easy to destroy if you do not remove them carefully.
If this answer was helpful please remember to return an mark it Accepted.
Score 1
Comments:
Thank you machead3, I reassembled but it didn't work. I didn't remove the heat sink. I think some little part on Logic Board is broken, so changing another Logic Board might be my final option.
by
Add a comment
Add your answer
Albert will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 794
