Model A1288 / 8, 16, or 32 GB capacity
583 Questions View all
it turned off, and it only works on power from the wall
I got it to work off battery for a while by hitting the back rather hard, but now that wont get it working, my guess is that something is loose inside. it will work from my wall charger adapter but not my computer. the instant i unplug it it cuts off.
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
Here's how to replace the battery: iPod Touch 2nd Generation Battery Replacement
Here's the replacement battery: iPod Touch Gen 2 Replacement Battery
Score 1
Comments:
I have dropped it once but it was in a case, so something might have come loose
by
Add a comment
Well I beat the !&&* out of it and it works again, but obviously, continuing to do this can't be very good. I have to hit the back to make it work
Score 1
Add a comment
You're just gonna have to open it up and inspect the connections. You might want to order a replacement battery so when you have it open you can replace the old one if needed. My guess would be a faulty battery as I doubt the connections could get loose inside.
Add a comment
The connections to and from the battery are soldered. Coming loose is a very slim possibility.
Comments:
well they ARE made in china. $*$^ happens to stuff made in china. Like the Toyota brakes. And the lead and the melamine and the exploding tires and the flaming laptop batteries and the radioactive childrens jewelry.
by
Add a comment
Add your answer
trevor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 847
