2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
962 Questions View all
Trackpad Button Not working But keyboard is Fine
Hi
My trackpad Botton seems to be not working correctly , I have spent Hours on Google and many people seem to have same problem But there keyboard is Not working also . where my keyboard seems to be working fine ..
Basically when I use the button it grabs and does not let go , i can push the button 5-10 times and will eventually let go but seems slowly getting worst ..
I have read posts about putting a Paper under the Cable But this does not seem to work - But the other small Flat Cable from the button to the trackpad circuit - if i wiggle seems to let go , paper or nothing seems to help .. the actual trackpad seems Ok does occasionally also Grab and not let go but not as much as the Button ..
I have read That you can replace the whole Cable to the Track Pad - But can you replace the small cable from trackpad to the Button ??
Nothing has been spilt on the Computer and I have tried cleaning under and around the button with a piece of paper etc ..
So does anyone have any suggestions - can I replace the small cable ? or do I have to Buy a whole top case or the main Trackpad cable ??
Thanks Mark
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Chosen Solution
If you can find the parts you could replace them - a simple fast workaround is a bluetooth or USB mouse.
''If this answer was helpful please remember to return an mark it Accepted.
Add a comment
Sounds like it's out of adjustment, there is a silver torx that you can adjust the pressure for the click if it feel flat no matter what the you need to replace the trackpad
Add a comment
Add your answer
Mark Watts will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,200
