Umidigi G9x Not charging
Start with the basics; your charger and cord. Either try them on a different device to verify they're working or try a different charger and cord.
Assuming those work, next stop is the charging port. Check it carefully with a magnifying glass and a bright light, looking for any debris or pocket lint clogging up the port and keeping the charger from connecting. You're also looking for any bent or broken pins inside. Clean it out with 90% or higher concentration isopropyl (rubbing) alcohol, a toothpick and an eyeglass cloth then try again.
If you still haven't found a problem, the issue could be either the charging port itself or the battery. A little research seems to indicate several users have had issues with the charging port on that phone.
Check those things out then come back and let us know what you find.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 13
