Shop the Holiday Gift Guide
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
My HDD isn't spinning up.
Hey, fellow fixers!
So in September, I was listening to some music on it when out of nowhere, it suddenly kept freezing, forcing me to reboot it. And when I put my ear up to the back of it (it somehow still has, or had, a functional HDD), I didn't hear the HDD spin up. Is the HDD finally dead, did something in the HDD break (I did drop it a few times), is there something on the motherboard that is broken (I can confirm that it at least turns on, however, it doesn't boot into RockBox, and has the sad iPod), or is this something else? I can confirm that the connections are good. Any help would be appreciated (And if you use AI in part of your answer, it would be plenty helpful if you state that, if you do answer. You may still answer, I just want that heads up)
Regards,
T
2 Comments
@user5136121 this "has the sad iPod" is a pretty good indication that your drive has failed. Of course, open it up and check the connector as well. Just in case it has popped off. The iPod Classic 4th gen has a pretty good audio IC, it's definitely worthwhile to fix it. Yes, HDD's are also still available.
by Share
@oldturkey03 - I already know that HDD's are still available, I learned that while browsing EOE! :D Guess that a storage drive replacement is in effect.
by Share
Add a comment
1 Answer
Chosen Solution
We prefer real humans here!
It does sound like the drive died from your description. As you tend to bang it about maybe a Solid State Drive would be better!
Here's one source for the needed parts to convert the HDD to SSD iFlash-CF there are a few others but the older 4th Gen needs an adapter.
Score 1
1 Comment:
@danj - Thanks for your response. I thought that the HDD has finally died. :(
I already have a iFlash at hand, but I guess that another wouldn't hurt. :)
Thanks again for your help. :)
by Share
Add a comment
Add your answer
Theo Grefalda will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 53
All Time: 53
