My truck horn is not working
Horn isn't working, relay are ok, fuse are ok, but from driving wheel doesn't send any signal to horn
@leticiadel91391, since your fuse and relay are good, the open circuit is inside the steering column. Remove the airbag and look at the contacts for the horn switch. The horn completes a mechanical ground to the IPDM relay. The internal spade terminal must be tight and the contacts must be clean and unbent. You can test the forward wiring to the wheel by grounding the horn signal wire just before it enters the clock spring. If the horn then sounds then the forward wiring is good and the problem is with the wheel. If the mechanical contacts are okay then the problem is with the clock spring. This is a common problem and can be accompanied by the airbag light flashing on and off and the cruise control buttons not working. Use a multimeter to test for continuity between the pins on the clock spring.
Since iFixit does not yet have a specific guide for that use something like this video You can also use these manuals to work on it 2010 Xterra Horn 2010 Xterra Steering System 2010 Xterra SR Airbag
Looks like the horn switch is built into the driver's airbag. I'd start by removing the airbag then shorting the two contacts on the horn connector to see if that makes it sound. If so, you'll probably have to replace the whole airbag; the repair manual doesn't show the horn switch being separately replaceable but you should be able to tell once you have it out.
You may need to go to the specific page for your year and 2WD/4WD page, but this page from the 2010 2WD manual should be the same or very similar.
Be careful when working with the airbag; the last thing you want to do is set it off. I would also caution you about turning the key on with the airbag disconnected; you'll get an SRS error code that will require a specialized scanner to clear. (Don't ask me how I know that :D)
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 20
