Shop the Holiday Gift Guide
The ThinkPad X200 was released in 2008. It leverages the new technology from the X300, including the options of a solid-state drive (SSD), an optional integrated camera, 12.1" widescreen display, optional 3G WWAN, a new 9-cell battery for extended running time up to 9.8 hours, weight as low as 1.34 kg (2.95 lb), and CPU up to 2.66 GHz Intel Core 2 Duo.
My laptop isn't working after I accidentally shorted it to ground.
I rebuilt the battery and accidentally shorted it to ground, when all the other parts are removed, it powers on normally. I suspect that the iosub card is shorting everything out. All the fuses on the motherboard test normal and I don't see or smell anything burnt.
Score 1
1 Comment
@zacheryle what parts did you remove? Did you remove the battery? How did you short the battery to ground?
by Share
Add a comment
Chosen Solution
@zacheryle this "when all the other parts are removed, it powers on normally" is good. Now reinstall each board individually. Meaning reinstall one board, then try to start. then next board etc. Once your computer does no longer restart, you know you have found the failed board. Replacing that should get your computer back on the road :)
Score 1
6 Comments:
Either it was the flex cable going to the iosub card or it was the card itself. But now im not getting any display including through the vga port, all the lights turn when booting on.
by Share
@zacheryle what parts did you remove? Did you remove the battery? How did you short the battery to ground? Now everything comes back on except you have o video? "all the lights turn when booting on." which lights? what you are describing now sounds more like a ram or bios problem
by Share
i removed everything and plugged back in the fan cable, charging port, ram, hdd, screen, and key board. i was testing the original battery that i rebuilt and one of the wires touched the metal plate at the battery slot of the laptop. When i get back i will see which lights turn on.
by Share
@zacheryle so you did remove the battery and just tried on AC power?
by Share
I did try it on only ac power since my battery is cooked from accidentally shorting it
by Share
Show 1 more comment
Add a comment
Most Helpful Answer
Hi @zacheryle
Unfortunately the motherboard schematic doesn't show the circuit details inside the battery, but I would still check the motherboard connection circuit of the battery to make sure that all is electrically OK.
Here's an image from the schematic that may help.
(click on image)
Score 2
Add a comment
I asked FixBot(Ai) your question and the result is a follows. Beware of Ai mistakes. I modified sentences for some clarity.
Does your ThinkPad X200 power on normally when running solely on AC power with the battery removed? If yes, your core system board is likely intact and operational. However, accidentally shorting the battery to ground typically causes one of two issues:
  1. Battery BMS / Fuse Trip: The short circuit likely tripped the safety fuse or tripped the protection circuit on the battery's internal Battery Management System (BMS), rendering the pack unable to output power or accept a charge.
  2. Charging Circuit Damage: If plugging the battery back in causes the laptop to fail to power on or boot, the fault may have affected the input protection or charging components on the system board.
To diagnose the battery pack, you can check its voltage using a multimeter as outlined in the hardware maintenance manual:
  • Power off the computer, remove the battery pack, and measure the DC voltage between terminal 1 (+) and terminal 7 (-) 1.
  • If the voltage reads 0V or is severely depressed below operational levels, the internal protection fuse has permanently blown to prevent further hazard, and the battery pack should be replaced.
Score 1
2 Comments:
@notbroken sounds to me like FixBot does not even consider this titbit of information "when all the other parts are removed, it powers on normally" :-)
by Share
I'm not expert on personal computers, laptops and cellphones and my meager experience in electronic, mechanical, and pneumatic systems, seems to me a possible battery management circuit gone south as my initial guess. This presumes the BMS is integrated into the battery pack, possibly one of the casualties when a battery short occurred?
by Share
Add a comment
If the laptop powers on normally when the other components are disconnected, that could point to a short or faulty component in one of the connected boards, cables, or peripherals. Your suspicion about the I/O board is worth checking. Try disconnecting it and reconnecting the components one at a time to see when the problem returns. Also, inspect the connectors and flex cables for bent pins or damage. Even if all the fuses test fine and there are no visible burn marks, a damaged power rail or component could still be causing the issue. If you have a multimeter, check for shorts to ground before applying power again. Be careful when working around the battery.
Add a comment
Add your answer
Zachery Le will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 90
All Time: 90
