The mouse won't turn on at all.
The mouse won't turn on at all. The battery is fine, but the mouse still won't power up. What can I check with a multimeter before throwing it away?
@milosfarsky check your battery for proper placement. Make sure that the polarity is right. Tehn check the battery contacts for corrosion and that they ar actually touching the battery. Next disassemble your mouse How to Open Your Logitech M220 Use you multimeter if your board actually gets power. This guide Logitech M220 Silent Mouse Left Mouse Button Not Working Properly Fix will help you to remove the board. If so follow the power and check the switch. Make sure that works. Now you will have to check the components etc. For that, go ahead and post a few pictures of YOUR board and let's see what it look like. That way we can see what you see. Adding images to an existing question
Guide
Difficulty:
Very easy
2 - 5 minutes
Guide
Difficulty:
Moderate
15 minutes
Guide
Difficulty:
Moderate
10 - 15 minutes
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 24
All Time: 24
it could be a bad solder joint at the battery that broke. Take apart the mouse connect the battery and check if your getting any voltage on the board.
by Zachery Le Share
If yours is around ten years old and used daily, consider wear and tear contributing to aging electronics. Other than finding a broken wire or severe corrosion creating intermittent connections (spilled coffee, soda, etc), electronics can fail at any time or last forever.
by F Dryer Share
