Shop the Holiday Gift Guide
Repair, disassembly, and troubleshooting information for Apple's "smaller" 2023 flagship smartphone, released September 22nd. It features a 6.1" ProMotion OLED display, a triple-lens rear camera system, and 5G. Successor to the iPhone 14 Pro.
How can I replace glass on the screen
The touch on the screen is working but its bad scrathed
Add a comment
1 Answer
Chosen Solution
Replacing the front glass is something that can be done, but frankly it's rarely worth the effort.
First you need a vacuum table to hold the screen after it's been removed from the phone. Then you need wires and wire guides to slice the Optically Clear Adhesive (OCA) that bonds the glass to the OLED display. After cleaning all the old adhesive from the display, you then apply liquid OCA and put it in a vacuum chamber to remove air bubbles. Finally it goes into a UV chamber to cure the OCA. That assumes you managed to separate the old glass without damaging the OLED, which is a very common thing to happen.
Since you have to remove the screen anyway, it's much simpler to simply install a new screen instead. Yes, it will cost substantially more, but to do it right you need thousands of dollars worth of equipment, so there's no cost savings here.
iPhone 15 Pro Screen Replacement - iFixit Repair Guide
Score 2
Add a comment
Add your answer
PaƄko Borgula will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 52
All Time: 52
