Powering up tempremental - is it the SMC issue?
Good evening, everyone.
My MacBook Air 2013 (A1466) has some issues.
To start with, the keyboard was water-damaged by the previous owner. I replaced the entire palm rest assembly with a second-hand one (including the keyboard and trackpad). As far as I can tell, the damage was limited to the keyboard, with only one known issue involving the D key.
Since replacing the keyboard assembly, my MacBook has started developing power-on issues.
- It powers on every time, whether connected to the MagSafe charger or running on battery power.
- After being left unused for some time, it won't power on, either when connected to the MagSafe charger or when running on battery power (even when the battery is fully charged). Pressing the power button a few times eventually gets the laptop to start. Once it starts, it works perfectly fine, with no unexpected shutdowns or other power-related issues.
- The battery has only 30 charge cycles since it was new.
- Resetting the SMC or PRAM helps restore the ability to power it on. After that, the power button works normally until I leave the laptop switched off for a longer period of time.
- I've noticed that when it struggles to power on, pressing the power button causes the fan to spin for a few seconds before stopping. Usually, after two failed startup attempts, it starts normally on the third attempt.
Should i proceed with measuring voltages on the SMC Chip ?
Thanks
Update (11/05/26)
It turns out that sometimes, simply cleaning the fan or shake it can improve things.
In my case, one of the cells in the internal battery had died.
https://discussions.apple.com/thread/522...
by mura mura Share
@marslo what I understand from your question is that it does something like ""spin, stop, spin, stop, boot". is that correct? Have you had a chance to check the logic board thoroughly for any corrosion? It does not sound like an issue with the SMC itself since the fan spinning tells you the SMC is already receiving the SMC_ONOFF_L
How comfortable are you checking the comports on your board? What 820-xxxx number is your board (I suspect a 820-3437 or a 820-00165)? Do you have the schematic for your board?
by oldturkey03 Share
@oldturkey03 Thank you for your reply. Yes, once the power button is pressed, the fan spins once, stops, spins again, stops, and then spins a third time. This time, you can hear the fan ramping up more quickly (it does make an audible noise), and the system starts.
It's worth mentioning that the laptop was powered off the entire night and started correctly with the first press of the power button this morning.
I'll check the board number once I take it apart again. Unfortunately, I don't have a schematic.
by Mariusz Share
@marslo no worries about the schematics I can provide a solution to that :-) Once you know the board number we can start checking things a bit better
@oldturkey03 Cheers, 820-3437-B board number.
Just checked the board with everything disconnected, and power supply connected to it: same thing, two spins, third spin starts the laptop.
by Mariusz Share
Show 4 more comments
