Shop the Holiday Gift Guide
Wine refrigerators, also known as wine coolers, are specialized appliances designed to preserve and enhance the quality of wines.
Condenser fan keeps starting and stopping, making loud thudding noise
Hi,
I have a Russel Hobbs Wine Fridge, about 5 years old. This morning, it started to make a loud thudding/shuttering noise every couple of seconds or so. (So loud I heard it two rooms over.)
I noticed that of the two fans at the back, the top one (I'm assuming the condenser fan) keeps starting and stopping, making the noise. The bottom one seems to be working fine. I turned it off for 3 hours, I took the back panel off, gave it all a clean, but it is still doing it.
I am not quite sure what is wrong, as I don't really know how they work. I don't know if this is a fixable issue or not.
Thank you for any help.
2 Comments
Hi @bethmay
What is the model number of the wine cooler?
by Share
@jayeff
It is RH12WC3
by Share
Add a comment
1 Answer
Most Helpful Answer
@bethmay
Not much luck finding a service manual or even spare parts for the model.
Do both fans have the same make and model number on them somewhere?
Post an image of the fans (both of them) in your question. Adding images to an existing question
If they're identical, you may be able to swap them over and check if the problem moves with the fan. Make sure to disconnect the power from the wine cooler before doing this
If the problem moves with the fan, then knowing the make and model number of the fan may help to find a replacement.
Score 1
2 Comments:
Thank you, I've attached some pictures I took earlier before cleaning to the question. Doesn't seem to have a model number on it from this angle. This may sound stupid, but do I just unscrew each fan and rescrew them into each other's place despite the wiring?
by Share
@bethmay
You would have to change their connections over to prove whether the problem is the fan or the control unit.
Just unplug them from the board and swap them there. Take pictures of the plug locations so you don't reverse the plug when inserting, although usually they only go in one way
You may also find the model number on the other side of the fan. Usually it's a sticker on the centre hub of the fan.
If there's a sticker on the other side of the fan this will help as well as there's none showing in your image
Good luck.
by Share
Add a comment
Add your answer
Beth May will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 74
All Time: 124
