Shop the Holiday Gift Guide
The screen colors have changed, looking as if a pale green filter has
After replacing the TV backlight, the screen looks as if a faint green filter has been applied.
There are no blotches or stains.
The screen has a subtle green tint.
I don't know what the problem is; please help.
The settings menu looks the same way.
Adjusting the color settings makes no difference.
The green tint is present right from the moment the TV logo appears.
I tried reconnecting the T-CON board and various cables, but the issue persists.
(LG_42LF6070)
Add a comment
1 Answer
@chbd4trqstcoxic that can be caused by aftermarket backlight strips that use low-quality phosphors. Those emit light with a heavy green or blue shift instead of pure white. Now, if the backlight shining through the LCD screen is already tinted green, the entire image will be tinted green. Software color adjustments cannot compensate for that. Turn the TV on in a dark room and look through the small ventilation holes in the back chassis. If the raw light bleeding through the metal frame (the smaller vent holes etc.) looks greenish-blue rather than crisp white, then the LED strips are the physical cause of the tint.
Now it is also possible that your TV lost connection on the pins carrying the Red or Blue data channels to the T-CON. That could cause a uniform green or magenta tint across all menus and inputs. Remove the LVDS cable at both ends. Clean the gold contacts thoroughly with 90%+ isopropyl alcohol and a lint-free swab. then reseat the LVDS cable ensure a proper fit.
Also check the ribbon cables going from the T-con board to the buffer boards. Check the connectors on the buffer boards to make sure that those are not accidentally pushed back or folded over themself (only seen it happen once but I guess its a possibility). Let us know what you find out.
Add a comment
Add your answer
ggg will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 46
All Time: 67
