Shop the Holiday Gift Guide
Repair guides and support for televisions manufactured by Sony.
Why is my tv not turning on
The red light don't show anymore but the green light comes on for a while then goes off repeatedly
2 Comments:
@mercyadusipoku what exact model is your TV and what have you already checked and tried?
by Share
@oldturkey03 The model is KDL-26EX302
by Share
Add a comment
1 Answer
Thanks for posting the model — a KDL-26EX302 with the green light cycling on and off repeatedly usually means the TV is failing to complete its power-on self-test. A few things worth trying before digging deeper:
- Unplug the TV from the wall (not just standby) for a full 5–10 minutes, then plug it directly into a wall outlet instead of a power strip and try again. This can reset a latched protection circuit.
- Unplug every HDMI and USB device first — a faulty peripheral or cable can hold the set in a boot loop.
- If the green light still blinks in a pattern (e.g., 2, 4, or 6 blinks), count them. Sony sets blink the LED in a coded sequence that points at the failing board, which really helps narrow it down.
On sets this age, worn capacitors on the power supply board are a classic cause of exactly this symptom, and it's a very fixable repair if you're comfortable opening the back panel. Good luck — let us know how it goes!
Add a comment
Add your answer
Mercy Adusi-Poku will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 29
