Why my MacBook freezing occasionally
I have a macbook pro core 2 duo with 2.53 Ghz and 4 GB Ram type mid 2009. Operating system is OSX Snow Leopard with the latest update.
Few month ago I replaced the original 256 GB harddisk with the new 512 GB because it freeze quite often and became soo annoying.
But the problem is not finished yet. Same issue happened again after 2 weeks of using it. Just for info, the new hard disk is not "apple" one. It was a 7200 RPM Hitachi which I think is good enough and have compability with apple macbook pro.
I run a test using Techtool Pro 6 and everything looks ok and nothing wrong. But i noticed that if I run something heavy such as resizing big picture, copying huge file (more than 2 GB) into my macbook pro, then it started to freeze. Usually when it freeze, it will last for around 40 secs up to 1 minute and then can continue working or sometime freeze totally and needs hard reset.
Anyone can help me for a solution? Thank you for your kind help in advance
