Released June 2012, Model A1278. Intel processor with Turbo Boost, Up to 512 MB DDR5 Video RAM
814 Questions View all
Why is the via connection to my MacBook Pro 2012 not working?
I tried to connect my macbook pro 13 to a projector and i get only vertical lines on the screen. I used the apple recommended Mini-display port/thunderport adapter to VGA but nothing works out. Any info is highly appreciable.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Try changing the resolution & cycle settings of your laptop. Projectors have (and you must know) resolution parameters or limits. Refresh rate Hz cycles also must match. I would imagine that if the external video is not showing up in System Preferences:Displays window you have either a resolution/cycle matching problem OR a connector/adapter problem.
There is a "detect displays" button in System Preferences to use if connecting the cables/adaptor doesn't automagically find a second display.
If this answer was helpful please remember to return an mark it Accepted.
Score 1
Add a comment
Most Helpful Answer
If VGA shows nothing...Plug in the VGA cable to the projector and the adapter. Then, close the Mac book while powered on, causing it to go into sleep...Plug in the adapter and open the mac book back up. It should work...thats what I have to do if I want to use VGA... My Mac book freezes when I plug in the VGA adapter with the screen open...
Score 1
Add a comment
Add your answer
Rajesheber will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 19
All Time: 2,640
