Shop the Holiday Gift Guide
Repair guides and support for televisions manufactured by Sony.
Sony XR-75X90L— 4 blinking red lights, no picture
My Sony XR-75X90L (75" BRAVIA XR, Full Array LED, 2023 model) is showing a 4-blink error code (red/white LED) on power-up, with no picture.
TV makes 3-4 loud relay clicks before settling into the 4-blink pattern — suggesting a protection circuit repeatedly tripping rather than a simple dead board.
What I've checked so far:
• Visually inspected the power supply board, T-CON board, and main board — no bulging capacitors, no burn marks, no visible component damage on any of the three
• Fuses on the power board (F6101, F801) look physically intact
Power board part number visible on the board: 1-017-135-11 / APS-453
Attaching photos of all three boards. Since everything looks visually clean, I'm trying to figure out whether this points to the power board's backlight-driving section, the LED strings themselves, or something else before I spend money on a replacement part?
Any guidance on what to check? or test next? would be appreciated.
Score 2
1 Comment:
Hello! I also have the exact same model (Sony XR-75X90L) in my workshop with the exact same 4-blink error and 3-4 relay clicks on power-up.
> I saw your comment on this post and wanted to ask if you managed to resolve this issue? If you successfully traced or fixed this fault (whether it turned out to be the power board, backlight driver, or LED strings), please share your experience and solution so it can help me fix mine as well. Thank you so much!"
by Share
Add a comment
The 4-blink code is worth paying attention to here. There’s a repair service specifically for the APS-453 / 1-017-135-11 used in the XR-75X90L, and they report 4 blinks as a common symptom of that power board failing.
I’d test the power supply/backlight outputs with a meter before buying a board. The relay clicking followed by 4 blinks sounds more like the set is trying to start and going into protection than a simple fuse problem.
Also, don’t assume an intact fuse means the power board is good. If you’re comfortable taking measurements, the next useful step is checking the standby voltage and the backlight/LED driver output during startup.
2 Comments:
Thank you, i will work on these recommendations
by Share
من این عیب و داشتم حااها حالاها برطرف نمیشه
یکی از vcore
های مربوط به cpu
در مین بورد در حال نوسان هست
و این نوسان هم احتمالا مربوط به
تغییر بکلایت ها هست
و معلوم نیست که عادی هست یا تحت فرمان
فرمانهای ایسی فلش ایسی هست
در
هر حال اشکال مربوط به مین بورد هست
به نظر من
by Share
Add a comment
@eibaad , my experience with sony indicates most likely a panel failure being detected in start up sequence. 4 flash indicates either ld_err (led driver failure on ld board) or bcm_err ( i2c chip on mainboard failure). on the led driver board, check pin 27 (3.3v) on cn1000, pin 4 (should read 3.3v) on main board. (the 30 pin flat cable between led and main boards in your pics) if the voltage is low (less than 3.3v on ld board) it can indicate the main board not properly communicating to led driver board, therefore a replacement may fix (ensure you install firmware after swapping board and soc from tcon to new mainboard in settings for proper display). if the voltage is high, it is communicating to the led driver board and the board isnt ramping up properly and may need replacement. however, if 1, the leds do not test open or undervoltage for the string, 2, the voltages are present from main and ld board, then it is the panel itself causing the protect mode. from experience, 8 times out of ten, after replacing both boards that cause a 4 flash, main and led driver boards, it does not resolve the 4 flash code. typical panel failure, but there always is the chance one of the boards will correct, if the voltages are not present.
Add a comment
Add your answer
Eibaad Butt will be eternally grateful.
Past 24 Hours: 12
Past 7 Days: 21
Past 30 Days: 43
All Time: 95
