Shop the Holiday Gift Guide
Repair information for Samsung clothes dryers.
Drum stop at sudden bang
When running a load there was a bang then the drum stopped on my samsung dry if I turn it backwards half a turn then it turns again sometimes for a few loads then it dose it again I am wonder what the cause is. Model # DVE45N6300V/AC
1 Comment
Hi @joerepai,
Not sure if the following will work but try pressing the Dry Level and Wrinkle Prevent buttons simultaneously for about 6-8 seconds and check if there's an error code been stored by the machine.
This is the procedure for other models in the DV45K and DV60K series of which the DVE45N seems to be included.
If there is an error code this may help too find out what's happening.
by Share
Add a comment
1 Answer
Chosen Solution
My guess is something is loose that holds the drum in position.
You will have to take it apart to eyeball it and find it before it totally breaks.
Score 1
Add a comment
Add your answer
jrepair will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 32
All Time: 108
