Shop the Holiday Gift Guide
The Nokia 3310, released in 2000, is known for being incredibly durable.
Find new battery and missing a contactor
Hi,
I've an old nokia 3310 and I want to change the battery. Where I could find a BMC-3 3.6v (Ni-Mh), and I charger please ?
But, there's a contactor missing like you could see it in the picture. There's a problem ?
Thanks a lot.
Ed
Score 1
Add a comment
1 Answer
Most Helpful Answer
@dw4rd5n0wd3n the original battery is a model CS-NKC2MH Do an online search for that since there are still stores that sell this battery. Yes, the missing contact is needed. The one that is missing is for the cell type identification. Your phone will not turn on unless it is connected. Luckily the battery connector is actually its own part. It is still availed at places like this and a few others. As for the charger you will need to do another online search and you may find something like this All of the links are examples only and not an endorsement for the sellers.
If you find this is all expensive or hard to obtain, consider something like this You can download The SM and schematics for your phone from this page under the Documents header Nokia 3310
Score 1
6 Comments:
Thanks a lot.
I'll try to do this on my own :)
Have a nice day !
by Share
I found a battery charger :).... it's working ?
I upload 2 photos
Thanks
by Share
@dw4rd5n0wd3n no, it will not. It has the wrong connector. Your Nokia needs a barrel adapter charger something like this Example only. Nokia part number ACP-7
by Share
Hi,
I've add 2 pictures of the phone. It seems there is a lot of oxidation.
Can I clean or I fix it anyway?
Thanks
by Share
@dw4rd5n0wd3n you are right, there is a lot of corrosion. You can try but first you need to clean the board. Totally remove it from the case . Remove the EMI shields from the board and then clean it with isopropyl alcohol. For a proper cleaning, use this guide. the steps apply to your board as well. Once cleaned, take some pictures lets see what it looks like then. Chances are very small on getting it fixed but anything is possible.
by Share
Show 1 more comment
Add a comment
Add your answer
3dw4rd5n0wd3n will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 63
All Time: 117
