Shop the Holiday Gift Guide
Why is the front right burner sometimes stuck on hi
On my whirlpool stove the front right burner sometimes gets stuck on high then I have to let it cool down a few minutes to get it to function again. It's starting to do it more often what could be wrong with it
Add a comment
1 Answer
Chosen Solution
To give you a definitive answer, we'd need to know the model number of your stove so we can pinpoint the issue. However, I've run into pretty much exactly the same issue before, so I'll tell you what I found.
Originally the burners worked by using a variable resistor to cut the amount of current going to the burner; the more current, the hotter it gets. However, newer stoves have switched to what's called Pulse Width Modulation (PWM) as a method of controlling the temperature of the burner. Instead of changing the amount of current going to the burner, the PWM controls how long the current is sent, turning it on and off rapidly. The longer it's left on, the hotter the burner gets, and the shorter the pulses, the lower the temperature.
In the case I ran into, the burner control had gone out, meaning it could no longer shut off the current; instead it was on full all the time. The fix is to replace the control behind the adjustment knob with a new one.
Once we know the model number, there's a fair chance we can tell you exactly what part you'll need and perhaps even find instructions for you on how to replace it. Note that the large and small burners use different controls, so be sure to get the right one.
Score 2
Add a comment
Add your answer
jrepair will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 41
All Time: 107
