My pc doesn't boot, but only in my home. Why?
My pc won't boot, but only in my home, basically it gives no output to any peripheral like my monitor and my keyboard, but the tower itself still receives power, fans turn on and everything.
I tried troubleshooting since this was something that has happen before but none of the troubleshoots i tried worked, so i send it to a repair shop and after waiting some days called back, apparently, my pc worked just fine in their repair shop and couldn't find anything out of the ordinary. This has happen twice now, the first time, my pc worked fine after picking it up and stopped working after a week, but now it just doesn't work.
Can someone please what is happening? I'm just extremely confused.
6 Comments
Hi @tochi55115
What is the make and model number of the PC or motherboard if it is a custom build?
by jayeff
it has an asus prime a320m-k
by tochi
@tochi55115 How much wattage does your WHOLE setup make? Try to use a PC wattage calculator and compare it to how much wattage your PSU can provide just to see if your PSU is underpowered. I would suspect that what the repair shop uses is very lightweight compared to an at-home build just to make sure that the basics works.
by Theo Grefalda
@user5136121 The pc uses around 400 to 500 watts, not including peripherals and such, and i'm using an 800 watts psu, so i don't think i could be a problem with the psu.
by tochi
@tochi55115 Okay, so that is out of the way...huh.
by Theo Grefalda
Show 1 more comment
