Where can I find the right ribbon cable and connector for my laptop?
I have a Dell Inspiron 15-7577 laptop that I’m very fond of. I recently replaced the keyboard, HDD, and battery.
Unfortunately, during the repair, the ribbon cable was damaged first. Then, while I was trying to reconnect and adjust the ribbon cable, the connector on the motherboard also got damaged and now the power button no longer works because there is no contact.
I’ve attached a Google Drive link with photos of the damaged connector and ribbon cable.
https://drive.google.com/drive/folders/1...
I previously tried using ChatGPT to identify the exact connector/part, but I’m not completely confident that it identified the correct one.
Since this laptop is almost 10 years old, my main question is whether this type of connector is still available, or if there is a compatible replacement that could be used instead.
I would really appreciate any help identifying the exact connector and finding a suitable replacement.
After a lengthy discussion, ChatGPT identified the connector as:
10 PIN – 0.5 mm pitch – FFC/FPC – Flip-Lock – Right Angle SMD – Bottom Contact
Possible part numbers:
- ACES 51530-01001-P01
- SP010025K00
However, when I search for these part numbers, the connectors I find do not look the same as the connector mounted on the PCB in the attached picture.
Therefore, I am not sure whether the identification or the suggested part numbers are correct.
Could you please help me identify the exact connector shown in the attached image and find the same or a fully compatible replacement?
I am specifically looking for a connector with the same physical design, dimensions, pin count, pitch, contact orientation, and PCB footprint as the original one shown in the picture.
Thank you very much for your help.
2 Comments
I did a quick search for parts to that model of Dell laptop. Dell does not have all the parts available but there was a site that has ribbon cables. Hope this is what you're looking for.
https://www.parts-people.com/index.php?a...
by Hast Share
Thank you for the quick response. I found it, but unfortunately, the ribbon cable is out of stock.
by Dominik Nagy Share
