Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
Why is my fan always running fast?
I have a problem. My CPU ist working and my fan always running fast? The temperature is ok?!? Can you help me???
Score -1
Add a comment
Chosen Solution
The fans run to cool the CPU when you're working it hard (videos, games and the like). To check the temperature you need to use a 3rd part fan application there are several out there.
Some steps to try before replacing the logic board if you have a bad temperature sensor. Be sure to purchase the proper tools to open your laptop - every job is easier when you have the right tools.
If this answer was helpful please remember to mark it accepted.
Score 1
2 Comments:
Thank you for fast answer....
The problem is, the fan is running fast when i turn it on!
The temperature is good! The CPU system is high?!? Why??
by
A bad temperature señor could be the likely cause this. - Use the second link above for more information.
by
Add a comment
whenever my computer is running fast I open it and clean ALL dust out of it,
Add a comment
Add your answer
Sven Ortmann will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,780
