Repair, disassembly, and troubleshooting information for the Steam Deck with LCD display, a handheld gaming console made by Valve, released on February 25, 2022. Identified by model number 1010.
Steam Deck turns on briefly, fan stops, screen stays black - won't boot or enter BIOS
My Steam Deck LCD won't turn on. When I press the power button, it makes a sound and the fan spins briefly before stopping completely, and the screen stays black.
Here is what I have tried so far:
- Forced shutdown (holding power for 10+ seconds)
- Connected the official charger
- Tried booting into BIOS (Volume Up + Power)
- Removed the M.2 SSD
- Disconnected and reconnected the battery
None of these steps resolved the issue or changed the behavior. Has anyone encountered this specific fan-spin-and-cutout behavior, and what else can I check?
Add a comment
1 Answer
Most Helpful Answer
Hi!
When it even don't want to enter the BIOS, it's not a good sign.
I would remove the motherboard and check for shorts. Check the fuses and also check for other damaged components.
Worst case: You need to replace the motherboard... This is not cheap, but the easiest route it is.
Guide: Steam Deck Motherboard Replacement
Sorry for the bad news...
Score 1
Add a comment
Add your answer
Jonathan Whitaker will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 55
All Time: 52
