Hi @robert82517
Usually the part number is found somewhere on the board itself, if you wish to confirm what it is, although looking at images of the board I can't see it
Best that I can find out from the limited info online regarding the cooler is that there's a compressor start relay mounted near to the compressor itself. Is this correct?
If there is then I'm not sure but with some refrigerators sometimes if the compressor won't start again after it has been stopped due to a correct temp reached condition and after a short while, the temp has then risen again therefore further cooling is needed but will start after a power reset it could be due to a faulty start relay.
Looking at images below of your control board, there also seems to be a relay which is used to supply power to the compressor (presumably also the compressor start relay if there is one).
If the compressor hums and then there's a click sound as it tries to start it could be the start relay. If there's no noise at all then it could be the power feed relay on the control board.
If you have a DMM (digital multimeter) you may have to use it to further isolate the problem.¹
You could check if there's 120V AC between the GND (Earth) or AC_N terminal and the Comp terminal on the board (as marked on the image) when the compressor should be running after it has been stopped and won't start again condition (do not power reset).
If there isn't it could be the relay on the board. The relay is a Churod CHZ02-S-112LA2 (example). You would have to unsolder it from the board then apply 12V to the coil (to operate the relay) and check if the relay contacts were working OK. Operate the relay a few times to make sure that the relay contacts are electrically closed every time as shown by the DMM (Ohmmeter function) If the relay was OK then there's another problem on the board
If there is, check if the power is reaching the compressor terminals. If it isn't then its the start relay.
If the start relay is the problem, hopefully there's some information on it that will help to find a replacement as I cannot find a parts list for the model.
¹ Be safety aware when testing for the supply voltage as it is 120V AC!
(click on image)
3 Comments
Hi @robert82517
What is the model number of the wine cooler?
by jayeff Share
Model is HWC241L
by Robert Share
I am told the main board number is DA81-08654A
by Robert Share
