Shop the Holiday Gift Guide
Repair information for Samsung clothes dryers.
Dryer vibrating noise after felt gasket replacement
I have a front load Samsung dryer, model DV45K6500EV . the felt gasket came loose so I had to disassemble the dryer in order to replace it  (part #DC97-07618A ordered off EBay) I read the manual and watched several tutorials to make sure I did everything correctly. During this process I noticed the belt had been grinding into dust so I bought a new one (GANCO  6602-001655 from Amazon) and also replaced that. Once everything was put back together, the dryer turned on but there’s a new, constant vibrating noise that I can’t specifically locate. I took everything apart again, double checked the belt and pulley (I noticed the screw holding the pullet piece in place was loose so I tightened it). I checked all four rollers, and the placement of the drum on top of them. I also double checked the felt lining at the front and back to make sure the drum was seated correctly. As I reassembled again, I checked that everything was screwed in nice and tight and no parts felt wobbly or loose. once again I turned the dryer on and the vibrating noise is just as bad. The dryer does work properly (I dried a towel for a few mins) but the noise is consistent and I can’t tell where it’s coming from. I’m considering replacing the  pulley assembly since I did adjust that, and replacing the back felt gasket in case having only the one new one is causing an imbalance. I can see the felt in front and back and I don’t see anywhere that looks like there’s metal on metal contact. I am so tired of taking this thing apart and I’ve followed the advice of several YouTube videos guaranteeing to fix noise problems. PLEASE HELP!!!!
Add a comment
1 Answer
Most Helpful Answer
Hi @brianafann
Check if the drum baffles are OK and not loose.
Couldn't find a guide for your exact model but here's a video that in general may help
Score 1
Add a comment
Add your answer
Briana Fann will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 60
