Replacing a speed(hall) sensor on my GE laundry center motor
I went to replace the speed sensor on my ge combo washer dryer and ordered the correct part. I received the sensor however the plastic bracket used to attach it to the motor is slightly different that the bracket that came off the motor - I confirmed that this is the correct replacement part, however the bracket had been updated. I am unable to get the sensor on the motor because this new bracket is slightly larger than the distance between the motor and fan. I'm not able to remove the fan - any thoughts on how to address this? the old bracket is broken so I'm not able to reuse it. Any body ever dealt with this issue before?
3 Comments
What's your exact model number, and what is the p/n of the hall sensor you ordered?
by Rhubarb Tau
@rhubarbtau GTUP270EM1WW - Laundry center - WL49X20360 - speed sensor -
Thanks!
by Jeff
Ok I checked the part with the link you sent - according to GE my part was discontinued and the part I have is the new replacement. The plastic bracket is slight to big to put in as the fan is in the way - the old bracket did not have this issue
by Jeff
