I want to upgrade my OS
i have 2gb ram and intel core 2 duo processor
i want to upgrade my os my present os is 10.4.11 to which os should i upgrade to with my present configuration
Your system can support Lion (10.7.x) If you can get your hands on Snow Leopard (10.6.x) it will work as well.
Before you upgrade the OS I would strongly recommend getting an external HD and making a full backup of your current internal HD (same or bigger HD, Firewire being the better ext I/O here). Make sure your system can boot under this external HD. Why do this? Well some apps you currently may not work under Lion. Besides it just a good practice just in case you need to reformat your internal HD or make a mistake.
You should think about up-ing the memory to 4gig and depending on your current HD size and what HD space you have used. You may not have enough space to install Lion. It maybe a good time to upgrade the HD to a larger one. If you do this you could get an external case to hold your current internal HD saving some time and risk of backing up (1st step in upgrading).
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 403
