Repair information and guides for the fifth generation of iPhone. Model: A1387
2192 Questions View all
How to screw in the top right corner display assembly frame screw?
I can't for the life of me get it to screw in. Theres a black piece that keeps you from getting the screw driver to drive the screw straight in so it just won't go in. If you're confused as to what screw I am talking about reply and I'll upload an image with it circled.
Score -1
Add a comment
Chosen Solution
if it's the little screw near the headphone jack, I find it heaps easier to remove the headphone jack. Don't completely remove it from the phone as the ribbons are glued to the frame, just peed them back a small amount so enough to get the jack out of your way.
Add a comment
When I do a repair 90% of the time I just leave it out( the other 10% ill give it a shot for 5min and sometimes i get lucky and ill get it in) because of the angle it is near impossible to screw it back in.
Add a comment
Some times is easier to put another screw smaller in mm (i take screws from iphone 4 from the vibrator right screw)
Add a comment
Here is how i've done it. I was holding the iphone head down to see the screw hole, then I took a screwdriver with magnet not to strong and, while holding the corner with one hand tightly, I dropped the screw in his hole. Then I placed the same screwdriver in the better angle possible and screw gently the screw into place.
Add a comment
Add your answer
Matthew Shaffer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,175
