Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Replaced LCD Has Vertical Lines - "HELP!"
I dropped my MBP a few months ago and I've just bought (for the second time) a new LCD for it. When I installed the new Lcd panel I got colorful vertical lines on a white background across the whole screen. I tried reseting the PRAM to no avail but some change in the vertical line's position on the screen with a 1 and half inch white gap between the lines on one part of the screen.
I know the logic board is okay, because I have it plugged into a desktop monitor and everything is fine. Do I need to send the panel I ordered back and get a new one? Or is this now a problem with my cable?
(also there is no going to a genius bar because the warranty is out on this laptop)
Score -1
1 Comment
I tried doing the safe-boot but I couldn't tell if it booted into safe mode. I believe it did because the external monitor turned on with the external screen reset as "next to" the macbook's screen where as when I reset they mirror each other because I sat there reaching into the void with the mouse pointer to pull windows over till I got the system preferences pane into view. So it DOES work with an external.
What should my next plan of action be?
by
Add a comment
1 Answer
Chosen Solution
Do a safe-boot if the problem dissapears you have an extension (software) conflict. If it does not then you have a hardware problem. Double check that the RAM is properly seated (since you dropped it)... the VGC uses RAM as VRAM.
If this answer was helpful please remember to return an mark it Accepted.
Add a comment
Add your answer
David will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,556
