Shop the Holiday Gift Guide
Acer entered the world of laptop computers in 1997 when it purchased Texas Instruments' mobile PC division.
Acer TravelMate B514-31 hangs on shutdown after BIOS 1.21 update
My Acer TravelMate B514-31 hangs on a black screen with the fans and power LED remaining on during every shutdown attempt. I have to hold the power button for 15 seconds to turn it off.
I have already tried the following:
1. Updated BIOS from 1.13 to 1.21 (flashed successfully).
2. Performed multiple battery pinhole resets (15-second hold).
3. Disabled Windows Fast Startup.
4. Updated and reinstalled the Intel Management Engine (ME) drivers.
5. Attempted a forced shutdown using 'shutdown /s /f /t 0' (still hangs).
6. Unchecked "Allow the computer to turn off this device" for the ME Interface and USB hubs in Device Manager.
Restarts are now working correctly after the BIOS update, but shutdowns still hang every time. Is there a specific driver version or BIOS setting (like a "Deep Sleep" or "Modern Standby" toggle) that fixes this for this specific model?
Score 2
6 Comments
I've got several TravelMate B514-31 units with this exact issue. I'm packaging three of them up to send to Acer for them to look at. If I hear anything back I'll try to remember to pass it along.
You can ignore the default MS copy/paste response from @jayeff
The issue persists even if you boot from a linux live USB drive.
by Share
@johnryan59546 I manage a fleet of this Acer laptops and found at least a dozen of them are having the exact issue as described here. Please post update how you go with Acer. I'll bring this issue to Acer on my end too and post update here.
by Share
@jovantanjt have you found the fix?
by Share
Not yet unfortunately
by Share
Acer requested I send them three laptops exhibiting the power state issue. I sent them three laptops. Acer then sent them straight back as "out of warranty"
The saga continues.
by Share
Show 1 more comment
Add a comment
1 Answer
Most Helpful Answer
Hi @jovantanjt
Try the following commands and check if they resolve the problem. You need to be online when doing them
Open a Run as Administrator Command prompt window (type cmd in the search box on the Taskbar and select the run as administrator option in the Command app) and type the following:
sfc /scannow then press the Enter key
When it has finished, type the following one at a time and allow it time to commence and to complete before doing the next one:
DISM /Online /Cleanup-Image /CheckHealth then press Enter
DISM /Online /Cleanup-Image /ScanHealth then press Enter
DISM /Online /Cleanup-Image /RestoreHealth then press Enter
Notes:
Yes there is a space inserted before every / symbol in each command string.
If you make a typing error, use the backspace key to step back and delete the characters until you reach the error and then start typing again. The mouse doesn't work in a Command window, it's keyboard only. Apologies if you knew this already
Once finished, restart the laptop and check
Score 1
Add a comment
Add your answer
Jovan Tan JT will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 56
All Time: 135
