CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
418 Questions View all
Where does this part of my item comes from?
I am reassembling my iphone 4 verizon after replacing my LCD screen and found this piece left out while reassembling. I wonder if anyone can tell me where this comes from. A picture will be great too
Add a comment
1 Answer
Chosen Solution
That is partly the cover for the Wi-Fi Antenna cap connector. The black part covers the the Wi-Fi connector, the gold part is a ground that inserts near the top of the logic board. The screw hole is at the large top stand-off screw.
iPhone 4 Verizon Upper Antenna Replacement
Score 2
thanks a lot! that really helped!!
do you know this too? I came across this piece 5 minutes ago. Thanks!
This goes at top of iPhone above back camera. The two prongs point up towards you at top of back camera space. The screw hole goes on top of top left screw hole of logic board, the screw then holds the ground down to the logic board.
Add a comment
Add your answer
leonard lie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 447
