The Kenmore Elite HE3 is a washing machine by Kenmore.
551 Questions View all
Loud clicking starting cycle and also FL error. What is wrong?
What is wrong with my Kenmore Elite HE3 washer. There is loud clicking at start of machine at times and today, would not start at all--had FL error.
Add a comment
1 Answer
Chosen Solution
PFS, I checked through the service manual but can not find any FL error (possible that it is FdL?). I would start off by trying to reset the washer. check this copy from a different answer "If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement. You can also try to reset the CCU by unplugging the washer for AT LEAST 30 minutes." you can download a service manual from here" Hope this helps, good luck.
Score 1
Add a comment
Add your answer
PFS will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 481
