Glass panel replacement iMac 27"
Is it possible to place a iMac 27" late 2009 glass panel in a iMac 27" mid 2010?
I can get a late 2009 glass panel.
I can give you dimensions on glass panel for iMac Intel 27" i7 (Model A1312, OCT 2009) as I have mine off to fix alignment pins. If you're still interested, leave a post.
A1312 glass panel dimensions (not including tabs) 25.625" wide and 15.25 high.
Four alignment posts are on the top edge of the glass panel and are symmetrical at the following distances from the side edge, 9.6875” for the outer posts and 12.1875” for the inner posts.
Six tabs are on the bottom edge of the glass panel. The outer two are different from the inner four in size. The outer two are 0.1875” long, 0.6875 wide, and are 0.3125” from the edge. The inner four are 0.25” long and 0.8125” wide. The leading edge of the tabs are located (from the right edge looking out the panel) at 5.5”, 11”, 15.3125”, and 20.875”. There is a small alignment pin on bottom at 14.75”.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,234
