How to remove back side cover of watch
Add a comment
1 Answer
To remove the back cover of your Accutime TWE5038, it is most likely a snap-on/snap-back cover. You will need a thin prying tool—such as a specialized watch case knife, a hobby/box cutter, or a micro flat-head screwdriver.
Safely removing the back cover requires a steady hand and these steps:
  1. Locate the Pry Notch: Inspect the perimeter of the back case to find a tiny indentation, lip, or slot. This is typically a very small gap meant to accommodate the edge of a tool.
  2. Protect the Watch: Wrap the sides of the case in a thin layer of electrical or painter's tape to prevent the metal from getting scratched if your tool slips.
  3. Pry the Cover: Gently wedge your blade, knife, or screwdriver tip into the notch. Instead of just prying straight up, twist the tool like a car key (or lever the handle away from the watch) until the back pops loose.
  4. Remove by Hand: Once it pops open, simply lift it off with your fingers.
Add a comment
Add your answer
Ashwini Mali will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 55
All Time: 111
