The original Sony PS3 controller that shipped with the PS3 from 2006-2008 (NO DUAL SHOCK 3)
How can I repair my Dualshock 3?
Good day sir/mam
well, few days before it got stuck on red light it was not blinking or not turning off I saw some online videos and resetted(via reset switch) it after then it rarely turns on and doesn't connect with my PlayStation 3 I even use scp toolkits to check whether it connects via usb or not well it didn't connect even i tried new usb cable It didnt work
So i require some helps for this
Thankyou
Add a comment
1 Answer
Chosen Solution
Hi!
Could be many things..
1: First I would replace the battery, just to check if it will at least turn on.
2: The USB port is broken and thus it does not want to connect, replacing this is recommend to test, but requires soldering.
3: motherboard issues. In this case, it will be difficult to repair and to check what is causing it.
Guide for replacing the battery: DualShock 3 Battery Replacement
Guide for replacing the USB port: PS3 Dual Shock 3 Controler Charging Port Replacement
Will try those things first.
Please let us know how it goes!
DualShock 3 Battery Image
Guide
Difficulty:
Moderate
10 minutes
DualShock 3 Charging Port Image
Guide
Difficulty:
Difficult
1 - 2 hours
Score 2
4 Comments:
Hello sir/mam
well i will try replacing the battery in the controller the battery is kind of bulged (srry bcs I didn't noticed it first) well i also placed a replacement and it will arrive in a day or two well also thanks for recommending the solutions. I will surely update it once the battery is replaced
Thank you
by
Thank you too! Then you really do need to replace it, yes. These days they are likely to fail. Please keep me posted, thanks again :)!
by
Hello sir/mam
sorry I know that it's been a week (srry for the delayed comment) and i switched the battery well actually it was working longer that before but as usual it did'nt charge or connects to the computer so i went to shop n change the port too now it is perfectly fine thank you for suggesting the repairs <D
Thank you, Sir/Mam
by
Hi!
I'm really glad that it's solved now :)! My pleasure! Happy to help.
Have a good day and take care!
by
Add a comment
Add your answer
Ambika will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 34
Past 30 Days: 148
All Time: 260
